Not so great update on the alloys - unfortunately the additional thickness the power coat introduces means the center sections on each wheel won't slot into the outer rim. I did think about getting the mating surfaces masked off, but just to ensure they would fit together nicely without any movement down the line if the powder coat was disturbed - but didn't bother in the end as I concluded it wouldn't be a problem.
Didn't consider for a moment that I'd have fitment issues post power coat - actually quite funny, full on Homer 'DOH' moment.
Not sure next steps - may buy an abbrasive disc for my angle grinder and just grind down the 2 offending surface, needs some thinking time.
Other than that, following the boot fix yesterday it's been a positive 24 hours
Wiper blades changed today as they had become very noisy - managed to pick up some genuine BMW ones on Ebay for £40, still a bit more expensive than most of the after market options (are they OE Bosch?) but takes all of the guesswork out regarding fitment or quality. Easy to fit, 2 minutes tops. Gave the glass a good clean and also used some 'Rainex' I had sitting in the garage, usually used for my motorcycle helmet visor. Never used on a car before so thought I'd give it a try.
Also fitted my new M-Sport wheel. Once I'd seen it in the flesh, I ditched the idea of swapping over the chrome bits from my wheel - all black actually looks a lot nicer.
Before: (apologies ///M police, it was there when I bought it)
After:
So, so nice. Amazing what a difference it makes just the added thickness and different texture. I had the same experience in my E85 when swapping out the standard skinny wheel for a Z4M wheel. Highy recommended. This is forum member Rassi's wheel, all the way from Belgium - perfectly packaged and pretty much pristine condition.
Also fitted a Smart Top I picked up on the forums. Fairly straightforward as the instructions are excellent - the only issue I hit was when fully assembled, I had a red flashing 'error' light on the module and taking everything apart and trying again didn't solve it.
Again, as per the instructions (mentioned in there in case of error) I removed the outer casing of the replacement harness and it finally worked ok, so it was 100% a connection issue. Looks like the chap I bought from also took this option as there were minor marks on the connector casing where it had been removed before.
Had the gap-tech on my E85 and the missing 'one touch' roof operation (both from a single button press inside the car, and from 3 presses on the remote) was annoying me, so a worthwhile mod.
