Mister T said:GuidoK said:It's not possible to mill a flat on where the lugs of the calipers are? and then drill a hole through or maybe a blind hole with thread insert?
That way you can make an angular bracket what is normally used.
You can definitely do that with a 17Z or 18Z caliper, not sure there's enough meat on those Alfa ones
You have hit the nail on the head. There just is not enough room to do that.
I have even thought about machining up a threaded blank and screwing it into the thread on the caliper. Then welding that. But the new hole will be right on the edge of the blank and very close to the outside edge of the caliper.
