So today I took off the rear prototype BBK parts and carefully inspected them for any signs of failure / distress…
All’s well..smothered everything in blue loctite when assembled after an initial loosening of a bolt ..boy it makes it hard work to undo..even after you’ve cracked the nut..
You can see how the Nordlock hardened steel lock washers bite even to the steel bracket..
Very pleased to see that the pad sweep is perfect and the combo of Ferodo DS2500 pads and F01 7 series 370mm disc are all good.
So about 5,000 miles and all well…
Just finishing off painting the production version of the brackets prior to fitting those.
