A
Anonymous
Guest
Grasshopper you have found the divine path to true enlightenment..
Yeah, I'm old school. I do the twisty connection and then solder it.Pbondar said:OK that works...maybe purely for test purposes use a temp connector on the speaker cables pending a sound check..but if all ok then definitely solder and insulate well then..these babies if instructions followed are quite good..
Yeah, never used those before. Of course, BTW I heat shrink after.Pbondar said:That’s how I did do it but started using these as you get a good clamp action on the insulation from the heat shrink plus they seem to solder well and seal the joint against water ingress plus a heat gun works well..I then bury it all in heat shrink..should be able to take 45+G no worries![]()
Yes, thanks, I'm using the speaker line inputs connected via the adapter loom. Yes, it's designed to take inputs from either RCA or line-in, so don't know how it regulates it. But it must I guess.Pbondar said:Grasshopper..be aware that the line voltage from the headunit is around 2.5v not 600mv..so according to your amp manual you need to use speaker input not rca phono input..not clear to me how that works since it seems to go the same inputs..
Class D amp create massive harmonics if overdriven especially on the input side..destroys tweeted in seconds..
I added a graphic above. That has given me more confidence. Will change them this evening. Off to do mandatory DIY now....Pbondar said:Thanks for the reviews...these Class D amps have sure changed things..seems to be quite common that the amp chips can run more power than the psu can supply..but then maybe the circuit board then goes up instead!
So the articles answer the RCS/speaker wire issue..there must be attenuation built into the adapter harnesses..so much for the comprehensive documentation..
Anyway lets hear it now pls!
OK, so I connected it all up, and no good.Pbondar said:Thanks for the reviews...these Class D amps have sure changed things..seems to be quite common that the amp chips can run more power than the psu can supply..but then maybe the circuit board then goes up instead!
That would certainly do it, but... I have run it like that before and all was OK. The only difference now is that the rears have been taken out of the equation. It all seems strange. I have gone over the connections again and again.Pbondar said:Well I would wire up the two sets of main speakers on the front two channels and switch to 4 channel mode and see what gives..that will eliminate some things..sounds to me, pun, that you have a wiring fault between amp n speakers but this step will verify that wiring integrity..
This has certainly given me a headache. I think I'll revert to 4 channel mode and cop the lower output.Pbondar said:If it’s not your wiring it’s the clever sh!t logic of the combo of selectable inputs and bridge mode..life was simpler when everything was hardwired..
Also the bmw outputs fall between two stools volts wise..another test is to frig the input with the phonos and see what gives..
