Hello, I'm sorry if this is a stupid question.
I have the normal 6 speaker system in my car as standard, but recently I have installed a Focal 165-AS3 system in my car. To drive it, I have fitted a Pioneer 4 channel in-line amp with a 100W output. Currently I am driving all speakers through this amp, but that means I have the two front channels (Focal system) being fed (via the supplied crossover) as well as the rears (100mm units in the rear bulkhead).
The rear speakers are standard.
So, what I have done is by-pass the rear speakers so that the amp only feeds the high powered 3 way system at the front, so as to remove the risk of blowing up the rears, seeing as their maximum input is only 50W.
Anyway…. Where I’m getting to on this is that I saw on the amp there is a switch to select 2-way or 4-way input. In the instructions there is no explanation, just ‘select what you want’. Can someone explain this to me? If I select 2-way does that mean that all the power will be transferred through the fronts?
TIA!
TIA!
