When to select 2 channel
Grasshopper let me know how it goes on 4 channel mode..as you say compared to the OE confit should be a marked improvement plus you can run the rear speakers off the other two channels..although I’d split the front inputs and run the rear speaker amp section off the front inputs as well as on the 6 speaker system the rear outputs are heavily processed..
All works OK. Strange.
Thanks for the help!
is that with the front outputs from the HU powering all 4 channels?
No, I just went with the 2 front to 2 front. Rear connections by-passed and went straight to the rear speakers.
Pbondar said:
Ah well a base line to start from..how does its souund then?
It sounds fine. Surprisingly (but not to you) the sound to the rear speakers is hardly compromised. It's OK.
Thanks once again for taking me thus far Master!
