Scottish Z4M Clubsport build
Nice build, looking good!
You can code this out I believe, can't remember his name on here but a chap in Bath did this for me as well as 'M track mode'. I haven't noticed it since he did the coding, other than usual fade on a hot day the pedal has been consistent since.
I was going to post the same - I coded ///M track mode and removed the emergency brake booster without any issues as a novice to coding. If I can find the instructions I followed, I’ll post them.
It doesn’t sound like that is your current problem OP (although it will be as soon as the brakes are working properly). I agree with an earlier post about needing to re-bleed the system.
Your car sounds great - I’m another who has arrived at a similar place by a different path. I’ve yet to fit my CoolerWorx shifter - it’s been sitting on a shelf in the garage for rather longer than I care to mention!
I have E36 strut tower reinforcement plates, KW camber plates and a BMW strut brace. I didn’t have any problems dialling in camber or with fitment under the bonnet with the OEM intake plenum.
