Scottish Z4M Clubsport build
Nice build, looking good!
You can code this out I believe, can't remember his name on here but a chap in Bath did this for me as well as 'M track mode'. I haven't noticed it since he did the coding, other than usual fade on a hot day the pedal has been consistent since.
I was going to post the same - I coded ///M track mode and removed the emergency brake booster without any issues as a novice to coding. If I can find the instructions I followed, I’ll post them.
It doesn’t sound like that is your current problem OP (although it will be as soon as the brakes are working properly). I agree with an earlier post about needing to re-bleed the system.
Your car sounds great - I’m another who has arrived at a similar place by a different path. I’ve yet to fit my CoolerWorx shifter - it’s been sitting on a shelf in the garage for rather longer than I care to mention!
I have E36 strut tower reinforcement plates, KW camber plates and a BMW strut brace. I didn’t have any problems dialling in camber or with fitment under the bonnet with the OEM intake plenum.
which brembo kit do you have? and what are the details on those discs? i might be up for a set for next season.
So things have taken a another step along the track route and I’ve added a rear wing.
Personally I think it looks great, might not be to everyone’s taste and have zero aerodynamic purpose but I designed the mounts myself so I’m happy. View attachment 297351View attachment 297350
At least the angle of attack looks vaguely plausible .. really need a suitable extended front splitter to create the impression of an aerodynamically balance car..otherwise too much rear downforce (in concept)
Spoiler is fully adjustable so can be moved to suit.
Fairly straight forward to make and only required 2 holes drilling for rivnuts and threaded bar to support the front.
Will be sealed with epoxy and painted.
Still need to work out how to fill the gap in the centre.
Ahh you mean something like this ? View attachment 297426
I used cheap garden edging trim.
Version 1
Version 2 (extended splitter)
  • Wow
Version 1
That’s exactly what I used as well, never cut it down at the sides though. Functioned great but now looking at exit tunnels to try and create some downforce. Also need to add a wide naca duct to pull air out from behind the oil cooler as the temps were creeping up slightlyIMG_1262.jpeg
Also, got a link to those yellow angel eyes ?
That’s exactly what I used as well, never cut it down at the sides though. Functioned great but now looking at exit tunnels to try and create some downforce. Also need to add a wide naca duct to pull air out from behind the oil cooler as the temps were creeping up slightlyView attachment 297582
Can I have the computational fluid dynamics working for this pls..? asking for a friend!-:)
I couldn’t be bothered trimming the sides on the 2nd iteration either 🤣
Re exit tunnels, just make sure you have really good bracing (i.e. chassis mount).
Re DRL, I tried a few but it’s either one of these 2, don’t recall where I landed but if I had to guess maybe the first?
It matches my light bar and helps tie the McDonalds theme I’m going for lmao.
So it was all going so well but started hearing the engine getting quite "Ticky" relative to engine revs. Pulled the rocker cover and check all the valve clearances...
Intake cam all within the 0.007" to 0.009" or 0.18 mm to 0.23 mm tolerance bar 1 that was marginally out.
Exhaust cam, every clearance was out by 0.002" or more, slid the rockers along and realised they all have flat spots :oops:
I was a bit unsure about tackling the jib but after speaking the the main man @RDMotorsport he talked me into in.
Vanos off, Cam sprocket removed, cam caps off, cam removed.
front slam panel and all brackets removed to allow clearance for the rocker arm rod to be pulled all the way out.
weighing up the cost of upgrading to shrick cams and dlc rockers and if its really worth the cost.
more to follow...
  • Wow
Schrick sell followers with more robust case hardening than OEM. If your cams survived the worn followers, the cheapest fix is to replace just the followers.
If your thinking Schrick cams too, the high lift cams give you more power at high rpm in exchange for a drop in torque earlier in the rev range.
You should consider changing the oil pump too since oil starvation is a common cause of premature follower wear.
yeh upon inspection the cams have survived, a good friend of mine has a few s54s in his container with bottom end issues and ive been offered to strip and take a set from that so just now that might be the best financial option. never gave the oil pump a thought but would expect to see it across both cams and followers ?
dont think i can stomach the £5k price tag on schrick cam for the gains compared to the amount of use it gets.
The case hardening on the followers is the weak link, so fails first. Once that’s gone, continued use takes out the cam lobes. It sounds like you caught it early.
I forgotten where the design flaw lies in the oil pump, but oil starvation to the head is usually due to the pump or heavy track use with high cornering forces on sticky tyres.
I did lots of reading around 15 years ago when I was considering high lift cams. The price was rather less back then!
OK I've been exactly here in 2019. the cams will almost certainly be scored too so you're into new cams and followers. I WISH I'd just gone for schrick cams when mine was all apart. At the time it was a mega bill within 8months of buying the car and with my wife pregnant I just made the decision to stick new oe cams and schrick dlc followers in (the dlc followers were cheaper than oe bmw at the time).
Overall, I saved a bit on mapping but looking back I wish I'd just got the sodding schrick cams - in the grand scheme the extra cost of mapping would have been insignificant!
Ah s**t, not a great end to the summer.
However, if you consider that diy’ing this effectively pays you, then a set of schricks becomes hugely discounted/almost free!
You’ve done well to catch that early, given how unpredictable an issue it can be. This is officially a Good News story. 👍🏻
