Rpi scoop and afe intake..
tertius said:
Interesting stuff, I had found their website but hadn't found an answer as to how it allowed for drag, which it obviously does using the drag coefficient and frontal area.
It doesn't mention GPS, does it rely entirely on the OBD port data for actual performance? In which case do you use a measured tyre diameter or a manufacturer figure? I guess tyre wear is a factor to consider.
Regarding your modifications if (as the name suggests) you are using ram pressure is the vehicle speed not a key consideration? And one that would not be seen on a chassis dyno.
Sorry for all the questions, but it is a fascinating topic.
You're right about the way that drag is computed and that it relies on the data from the ECU for performance. As for tyre diameter, I use the figures produced by a tyre size calculator such as found here: http://www.etyres.co.uk/tyre-size-calculator.htm With regard to my Z4MC, the tyres are new so I haven't made any adjustments, but when they get part worn (I measure them with an electronic vernier caliper gauge) I make the appropriate deduction from the circumference to keep the recordings as accurate as possible.
Yes, ram pressure is what it's all about, and as you say, speed is a consideration. A chassis dyno operates in still air, so unless you rig up some form of speed related blower system, you'd never know what's actually going on.
I agree that this is a fascinating subject, and it's certainly kept me interested for a long time and I've done a lot of study and learned an awful lot a long the way, which has hugely added to my enjoyment of owning 2 of BMW's finest M cars. :D
over 70whp from an induction mod you home made? thats ESS vt1-445 territiry. id like to see pictures of this on your car. or do you not open your hood to show anyone?
You seem to be focusing on the HP figure and not the increase in torque. Ask yourself, is an increase in torque a possibility and do you think that an increase in torque of around 8.5% (as my datalogging shows) could be possible? If you think it is, then ask yourself, what would happen to HP figures if the increase in torque could be maintained throughout the rev range to the redline rather than dropping away as usually seen in dyno plots? Have you ever done any experimentation with the air intake and datalogging of your Z4MC, if so, what are your findings?
I fully realise that I'm going to get flak from some folk for revealing my data, but If you think I'm embellishing or making these figures up, I can assure you that I would've found better ways of spending my time than all the R&D that I've done with my ideas and developments and found that I was making no progress. I'll tell you the secret: it's all about Volumetric Efficiency. :thumbsup:
I think you should duct-tape a stock intake around your head and take a few deep breaths... Then do likewise with a AFE Pro5r filter. You'll find out INSTANTLY which breathes better. This is about as scientific as your bubble-gum approach to all of this. You'll be laughed down the street in any real-world capacity with your claim of an 8.5% increase in TQ with your 'pressure-water-tested-home-made-intake - let alone the outlandish HP numbers. Regardless, if you think BMW left all that power on the table with the S54... Then I've got a bridge to sell you.
If a supercharger can double the HP, then why could other systems not make gains of 8,5%? I'm pretty sure that in- and outflows can always be optimised. What BMW knows today, they might not have known back in 2003... I'm interested to see the results from a bench test afterwards.
To be fair these are extraordinary figures so I think there is likely to be a fair amount of scepticism.
I'm not an expert but a quick calculation suggests you would need a BMEP of 15.5 bar at peak power. That is more or less unheard of for a production NA engine. I used 15% for transmission losses, to arrive at a flywheel figure.
Given the need for actual road speed you need a side by side straight line comparison with a known car to answer the doubters, somewhere like VMAX would be the ideal.
You're claiming that your AFE intake breathes better than the OEM intake set-up, yet you're also telling me that I think BMW left power on the table. It therefore seems that you think BMW left something for you too! So why didn't BMW save itself a lot of money and simply fit an AFE filter like you've done?
Tell us; how is it possible for a normally aspirated F1 engine, with a 2.4l displacement, to make around 720bhp. I've guessed; they use your AFE filter! :rofl:
SweetRide said:
... This is about as scientific as your bubble-gum approach to all of this. You'll be laughed down the street in any real-world capacity with your claim of an 8.5% increase in TQ with your 'pressure-water-tested-home-made-intake - let alone the outlandish HP numbers. ...
fair enough it's a ambitious claim, but your hyperbole is a bit ott. much like when graeme obree rode a bike 'made out of a washing machine', when all he had used was a bearing from a washing machine to reduce his q factor.
I agree that the figures are large, and the HP figure is definitely more than I was expecting. As I've said, I realise that I will get flak from some folk, but I know that these figures were produced in exactly the same way as all other recordings. So I'll simply have to take the flak if/when I produce data. I also know some people are just downright rude and insulting when making critical comments.
If you compare the figures with those I've produced for my Z3MC, with the same S54 engine, you'll see they're pretty much comparable up to the same revs. My mod has set out to harness the ram effect to its full potential, therefore, when it is able to do this, the increase in forward speed produces an increase in static pressure within the air-intake system, which increases exponentially. Therefore, as the rpms increase, the increase in ram pressure compensates for the expected loss of pressure within the engine, thus the torque level is maintained right up to the redline. I was shocked to see the bhp figures myself, but not the torque. It's only when you think about what is happening within the air-intake/engine that you realise that the exceptional HP is due to the increased torque being maintained by the air-intake being highly efficient up to the redline. HP is a measure of "work done per unit time". I've simply managed to achieve what I set out to achieve.
I've been in arguments/discussion in the past about the effectiveness of the ram-effect and originally got into datalogging to find out for myself what is actually happening inside the air-intake system. Some folk demand the proof and if you don't provide it, then you're damned, and when you do produce it, you're damned again. As I've said, if I didn't know I was onto something, I wouldn't have wasted my time investigating all this.
Below is a graph showing the theoretical increase in ram pressure versus forward speed. The pink spots are the actual values that I have recorded at the front of my Z3MC with a Magnehelic differential pressure gauge (very accurate). As shown, the real-world conditions confirm the theory. Likewise, harnessing an increase in pressure is going to produce a performance gain when compared with the usual pressure loss seen in a NA engine, and the better the ram pressure can be harnessed the better the gain will be: it's all about Volumetric Efficiency. Simples.
Personally I don't see why people are getting vexed by something somebody is doing as a project using their own time, initiative and investment.
Question, yes. Query, yes. Even be a little cynical if you like, but don't piss all over another mans ideas because you don't agree. It's very rude and you're likely to end up with wet trousers.
Nicely said. :thumbsup:
john, are you seeing any positive pressure with your ram setup?? is that possible?? like maybe 1psi or something at high speed???
well done for giving it a go....
all a supercharger does is shove huge amounts of air is so i guess if you can design something that does the same.... well...... its going to make more power!!!
edit.... i may be completely wrong :-)
Byron,
Yes, I'm working with the OEM, rather than against it, which I think is a superb starting point.
As you say, this is just a mild form of supercharging.:thumbsup:
Well, I certainly admire you for putting the effort in but I guess I have to declare myself a sceptic. Whilst I don't doubt that there is potentially some gain from ram effect I find it very hard to believe it is that significant at normal road speeds.
Some simple comparisons make your data difficult to accept, for example using the BMEP figure I calculated earlier (15.5 bar), means that your engine is doing a better job than a 2006 Formula One V8 at peak power (2.4L, 750 bhp at 18500 rpm) with a BMEP of 15.1 Bar.
A few things occur to me:
1. first on the DashDyno and using it to derive horsepower will mean that air resistance figures are crucial - how have you arrived at the figures you used? E.g. drag coefficient and frontal area. Moreover, what allowance is made for rolling resistance, wheel spin etc? I'm sure there are other variables that are also significant and may be worth checking.
2. on your power comparison graph why do the standard and first modded graphs finish at around 7,000 rpm - well below peak power?
3. have you tried charting power vs road speed? If the ram effect is significant this should show it.
4. can the S54 engine actually use more air? By which I mean if it is possible to significantly increase the density of the air entering the engine, then the engine will need more fuel to burn efficiently, and the ECU will need to be able to support this.
Have you done any side by side runs against another Z4M coupe? An event like VMax will allow two cars to run side by side in a straightline. Achieving high speed is basically a function of power vs aero, so running against a similar car will eliminate the aero variable; and if something like a VBox were used it would give absolute performance data.
Tertius,
This is LONG, but you did ask. :wink:
<EDIT>
Which formula have you used to calculate the BMEP of the Formula 1 car and mine, and what numbers did you use? What BMEP figure did you calculate for mine?
<EDIT>
Firstly, I’d like to say that I do understand the skepticism that may surround this subject and my figures. I’ve read LOTS of discussions on a host of different forums, and ram-effect and the use of dynamometers seem to be the two subjects that really polarize opinion! Postings like that of SweetRide are not unusual, but I much prefer postings like yours, which are in the spirit of serious and polite discussion. :thumbsup:
As I’ve said earlier, I originally got into datalogging in order to find out for myself what really goes on in the air intake and the effect on performance because there’s very little factual information so discussion without the information doesn’t really lead anywhere. From my research it seems that ram-effect for car intakes was pursued in the 1950s, particularly by Chrysler for its commercial products, but also by various independent engineers for race applications. There were several problems though back in those days: electronic fuel injection (EFI) wasn’t available and cars were not equipped with a host of electronic devices working in conjunction with an ECU which could be observed and datalogged so understanding the principle of ram-effect in real world driving conditions was hard to asses. In those days, fuelling was with carburetors, which required balancing fuel flow with the airflow passing into the engine and if you’ve ever done any carburetor tuning, you’ll know that you have to find a sweet spot as the “best compromise” adjustment, whereas with EFI, fuelling is optimized under all airflow conditions.
The problem with an air-intake which harnesses the ram-effect in conjunction with carburetors, is that the flow of air is variable and consequently, this means that the carburetor will perform differently at different speeds and in different gears/engine rpms. As such, ram–intakes caused unsolvable problems and so ram intakes fell out of favour. As such, there’s very little information about the use of ram-effect for road cars using EFI in the public domain. Any information, with actual data is very hard to come by, and despite searching incredibly hard, I’ve yet to find the sort of data that I have produced, although there may be others treading the same or similar path to me. Consequently, I consider that the study of ram-effect and its possible usefulness is a puzzle for which I need to piece together the clues as and when I find them. I've had to follow my hunches and intuition, based on my findings, throughout.
Whilst a static dynamometer can be a useful tool, it is in fact a “one-trick pony” in that it provides information about torque and power, only. The accuracy of them, the repeatability of their measurements and comparability from individual dynamometers and those of different manufacture, seems is still open to debate and will always cause argument. In comparison, the DashDyno and other datalogging equipment connected to a car’s ECU via the OBDII socket simply reads and records whatever information the ECU will yield. The same information of Intake air temperature (IAT) air-flow through the MAF, engine rpm, and a host of other PIDs (Parameter Identities) are used by the ECU in controlling fuelling using the engine mapping system provided by the manufacturer, or from aftermarket remapping. I therefore consider that the raw data recorded by a DashDyno is 100% accurate and that the DashDyno is an advanced hi-tech piece of equipment and certainly not a toy.
So, when it comes to using the DashDyno as a real-world dynamometer to record “at the wheels” figures for torque and hp, the device uses the data from the car’s ECU coupled with a car specific “profile” which is entered by the user (i.e. me) and this is used by the DashDynos software to compute its dyno results. For all my dyno runs in any car I always use 3rd gear and so I set up the profile for each car with the published weight (allowing for my weight and fuel), 3rd gear ratios, Cd, frontal areas, tyre diameter, geographic elevation, ambient air temperature, pressure and humidity. I always do my dyno runs on the same private road and when it’s not very windy and I use a couple of local weather stations with websites to get the environmental conditions at the time of my runs. When performing the runs, I cruise in 3rd gear at low revs until the green light comes on the DashDyno and then I give it WOT and hang on! When I stop the car the DashDyno produces the saved data as a plot of torque and hp. I’ve been using the same methodology throughout my datalogging of all different cars and with various different modifications under test so that I can ensure repeatability and accuracy to show me whether a modification has any significant effect on performance. I have absolutely no interest in attempting to produce bogus figures to fool anyone, because I’m looking for enlightenment and knowledge of what actually happens to performance with mods.
To answer your specific questions:
1. The figures are produced by the DashDyno after a run using the profile loaded for the car, as described above. There’s no wheel spin in 3rd gear. The dyno results that I obtained from the Dashdyno for my Z3MC are very comparable to those obtained on the dynamometers of Evolve and Powerstaion (as I’ve posted earlier in this thread). Likewise, the dyno results I’ve obtained with other cars in OEM state are very comparable to the manufacturers published figures and with modding of their intakes, I’ve seen significant improvements in torque/hp. I therefore consider the DashDyno to be accurate and to be reliable. Since the DashDyno produces “at the wheels” figures, only, there is absolutely no estimation of “at the flywheel” figures as used by static dynamometers, and so what you see is what you actually get, at the wheels. I therefore consider this to be a better way of measuring a car’s performance, because there is no favourable guesswork of adding “losses” into the results.
In any event, even if my DashDyno were not 100% accurate and is over-reading the dyno results, any increases seen from my modding are "relatively" greater than OEM, so gains are still being produced "relative" to OEM, so the gains are still significant and real, although the quantum may be in dispute. However, I don't see anyone challenging the OEM figures my DashDyno produces. :poke:
2. Because I lifted off before getting to the redline. As I’ve stated in a previous posting, in my ramcharger mod run, I lifted off slightly to go over a slight crest in the road and then went back on WOT. If you lift off too much the DashDyno considers the run has been terminated and so only calculates for the duration of WOT in that run.
3. Yes, the data recorded by the DashDyno can be exported into .csv format, which can be used in Excel. I’ve made an Excel template, which calculates a “rolling” Volumetric Efficiency (VE) from specific data that I log. I’ve found that by observing the graphical performance of VE has been most helpful in helping me to understand exactly how the air-intake “works” and how ram-effect can be improved with specific mods to increase dynamic pressure (i.e. ram effect).
4. So far, I’ve found that the S54 engines in both my Z3MC and Z4MC have been able to use all the air that I can give them, without any need for a remap. The S54 has a published VE of 105% but in 1st gear it only achieves up to 70%, in 2nd gear up to 90%, but in 3rd gear and above the VE can go above 100%: this difference occurs due to the OEM intake harnessing the ram effect. In the case of the Honda S2000, the published VE is 115%, yet if you read the S2000 forums, owners seem to want to ditch the OEM air-intake, which makes a VE of 115% possible in favour of some aftermarket kit. I find this laughable! Most people just don’t believe or understand how all this works. :headbang:
As previously said I’ve done a similar ramcharger mod for my Z3MC and I gave a link to a video of me chasing another Z3MC. I know the owner of that car very well and have driven with him a lot. He is hugely experienced and has instructed many others at The Ring, and he taught me the lines on my first trip there. Both our cars have the same aero mods and I’ve followed that car around The Ring before and we were very evenly matched on previous trips. On my visit shown in the video, I’d recently manufactured my ramcharger and I was astonished at the way my car could catch him up on the straight sections (where driving ability is not a factor – that’s why I showed that section). Here's another one: http://www.youtube.com/watch?v=ICLoOSJEkpY
I’m going to The Ring in April and will have the opportunity to run with several other guys I’ve driven with at The Ring before. I shall record my runs with my DashDyno up and running and I will then have lots of data to see how the car performs at all speeds.
FYI, my Z3MC in OEM condition, will maintain the pressure, at ambient pressure or above, within the air-filter box at WOT, in all gears and at all speeds above 90mph, but with a series of different mods, including a ramcharger mod, I’ve managed to get the same car to now maintain the pressure, at ambient pressure or above, within the air-filter box and perform at WOT in all gears at speeds above 60mph, and my ramcharger reduced this from 80mph with all previous mods. My experience of developing my air-intake mods for my Z3MC was part of the reason why I bought my Z4MC, because I wanted to see if I could do the same/better with a S54 engine with a slightly different OEM intake.
Throughout my experimentation with modifying air intakes, I've never made any predictions of what performance increases that I expect to see. I merely make a change that I think might work and then datalog in a "suck and see" approach, just like all the inventors of the past have done. :thumbsup:
Are you still awake? :rofl:
exdos said:
marksdesigns said:
Someone say carbon fibre? I'm always here to help if you need some cf treatment.
Woots, pm me if you want to keep info classified.
:police: :police: :police:
Mark, Do you fabricate CF parts from scratch? Where are you based? Do you have a website? :thumbsup:
Yo mate, i do mainly CF lamination, no website yet i afraid, work for main dealers and Z4's on the side!
