enuff_zed said:The motor ecu is not actually part of the column though. It is an issue with cheap components within that ecu failing.thecremeegg said:enuff_zed said:About £600 to send your complete column, with motor, to BBA Reman for a complete overhaul with lifetime warranty. But their turn-round time is 3-4 weeks atm!
In the OP's case it is an EPS ECU fail though, not sticky steering.
For £600 I can get all the parts for Hydraulic steering and won't have to deal with this crap again. OP's column is starting to fail, it's just a matter of time sadly.
I don’t see how this can be construed as the column starting to fail?
The three I’ve had returned have all had the very light smear of grease they left me with. Never added any more and they’ve been fineJoez4 said:My motor is now on its way back I can only assume its been repaired as I had no phone call to confirm it was broken or not.
With regards to fitting do I need to grease the shaft of the motor before fitting and if so what type of grease do I use?
Also I want to have a look at greasing the rack and universal joints as I had creaking sounds from the steering on cold days, what grease is recommended for that job?
thecremeegg you'll have to let us know how your steering conversion goes.
Good news.Joez4 said:So my motor is back in and ista now finds it and four fault codes are in its memory with none currently active.
The one bolt was easy enough to nip up with just my finger and thumb but the one nearest the steering wheel was just as difficult to nip up as it was to get out but I managed it.
I will say if it hasn't been mentioned before that it is far easier to install the ring to the motor before you try to fit the motor to the column as I could not get it to sit right on the motor and had to take it out and start again once I did that the holes lined up and it was straight forward.
Thank you enuff_zed for the info for removing and fitting, I don't think it would have been so straightforward doing it without the knowledge you provided and hopefully the next person with my issue finds this thread just as useful for them.
Just need some decent weather and I can take it out for a test drive.
About 7-8mm bottom edge towards the pedals.Joez4 said:So I've been out for a test drive and the steering seems much more responsive at low speeds not sure if this is some sort of placebo effect or not but I have noticed some slight notchiness in the steering at speed it's like the wheel locks at dead centre and it takes a slight tug of the wheel to move it out the notch I guess I've maybe introduced a bit of tightness to the steering, anyway now that I'm well familiar with how to adjust the steering it seems stupid to not try and dial this out.
Which way do I turn the ring to loosen the steering?
Assuming I'm lying with my head on the pedals looking directly up do I rotate it towards the pedals or towards the rear of the car?
