PM'd you my mobile if you need any moral support.portculisz4 said:enuff_zed & firelobby
Excellent information, you have both given me the comfort I need to do this job, first thing monday (hopefully no rain) I will be on to it.
It's highlighly likely that it's the motor, but you can check the voltage at the plugs themselves.portculisz4 said:I know the steering ECU has a failure record but before I strip the unit out for check up and servicing, are there onboard things I can check to possibly eliminate the steering ECU. I wondered whether there is a separate fuse for steering ECU and this could have failed.
I couldn't actually get my column out without removing the motor, so I ended up doing it both ways. Wouldn't recommend!thecremeegg said:firebobby said:Don't need to remove the column, the motor/ ECU will come out.
You don't apparently NEED to, however you have to do nine tenths of the work of removing the column to get the motor so you my as well just do it as it's MUCH easier. I couldn't get the motor out on its own, just wasn't enough room so I took the column out instead.
I had the dreaded EPS failure a month or two back and as others have said, sent the motor off to ECU tuning (go via their Ebay page here - https://www.ebay.co.uk/itm/401352168863 - as it's cheaper than their website) and now it's back and all fixed.
All very quiet? Hope you're not stuck in the footwell?portculisz4 said:enuff_zed & firelobby
Skeletal pair of legs hanging out the doorenuff_zed said:All very quiet? Hope you're not stuck in the footwell?portculisz4 said:enuff_zed & firelobby
Excellent information, you have both given me the comfort I need to do this job, first thing monday (hopefully no rain) I will be on to it.![]()
If you lift the carpet you'll see another loom that connects to a sensor mounted under a metal bracket. It senses lateral/longitudinal movement and works with the traction/dsc and other nanny state aids. Usual scenario is the door membrane leaks, it gets wet and throws up codes.portculisz4 said:Not sure what the yaw sensor is. I found a connector under the drivers seat that had to be removed before taking the seat out but assumed this was for the seat belt sensor and any driver presence sensing that may exist within the seat. I have place a cushion over the cable and plug so as not to damage it when climbing in and out
Hi Ant,portculisz4 said:Firelobby & enuff_zed
No, not stuck but delayed with a painful neck muscle strain so a few days late getting started.
Progress so far - I took the advice of enuff_zed and have removed the seat, steering wheel and steering column shrouds as well as the the long column stud and spring to get better visual clearance. Getting late so will look at the motor removal first thing tomorrow. The tools I have to remove the EPS are an 8mm ratchet spanner, or an 8mm hex socket and 1/4" ratchet or also the correct size torx socket for a 3/8" ratchet drive, would like to know what tools you found the most suitable. Are the EPS torx bolts on very tight, not sure with the clearance available as to whether I can get enough leverage with any of these options. At least I can work upside down now. I have marked the eccentric spacer ring and EPS casing so as to get them back in the correct position,
question - does the eccentric spacer ring come away with the EPS or is it basically situated in the column housing ??
Anthony
That way works just as well. However, my policy of dismantling as little as possible meant the ratchet spanner was better. It's no wider than the head of the socket handle so you can put it straight on, not have to get a straight line from the other side of stuff (if that makes sense)firebobby said:Hi Ant,portculisz4 said:Firelobby & enuff_zed
Anthony
Basically what you have been using, tool wise.
This was after I did my motor, is part of the link I added above, hope this helps Screenshot_20220611-090544.png
Result! Well done and a great improvement with the clutch pedal.portculisz4 said:enuff_zed
Progress - there at last with the EPS motor now sitting on my work bench. Your advice about removing seat and steering wheel and other steering column garbage worked well. As you say, weedling it out from the column with all the cables around was the fiddliest bit and the two cable ties fixing the black plastic cable to the motor body didn't come up as a restriction until the very end. The 8mm ratchet spanner was definitely the answer with a copper tube extension to break the initial bond, I fixed the clutch pedal down by removing the clutch back stop and replacing with a 10mm bolt with wire tie secured to it and then tied the pedal right down to the floor to avoid having to mess about with it while wriggling the motor out. Well off to ECUTesting on monday and hopefully it will be back within a week. Will definitely touch base with you again on the re-installation, I assume the worm gearing on the motor shaft will align automatically with gear teeth on the column shaft. Also as you mentioned, the eccentric adjustment ring has stayed in place so will hopefully be in the correct position on motor replacement.
Bit late but I painted some lines on the column / ring / motor using nail varnish when adjusting it so I knew where the default position was.portculisz4 said:Also as you mentioned, the eccentric adjustment ring has stayed in place so will hopefully be in the correct position on motor replacement.
I used some EP2 lithium grease.portculisz4 said:I noticed the worm shaft on the motor had some grease on it after removal so my question is, is it necessary to re-grease the shaft and the recommended grease to use if it is ?? - I thought the motor worm drive engaged with a non-metal gear inside the steering column and that grease wouldn't be necessary.
Oh bugger! Not good, but still think you've fixed one problem if it can now communicate, so not changed in vain.portculisz4 said:After a couple of hours re-installing the EPS motor, finally connected the battery and started the car, great news, no EPS fault light and the steering appeared to be back to normal (the airbag light came on but I reset the error code and no further problem there). But the news was not good - after leaving the car for about an hour, went out for a test drive, started the car and the EPS fault light back on and steering heavy. I connected the OBD2 unit and this time there was communication with the power steering ECU and the fault indicated was - '611A PHASE VOLTAGE, SERVOMOTOR'. I could reset the fault and the steering appeared OK, ran a 10 mile test drive and no problems. Parked the car and left for about 10 mins and retried, fault light back on again with same fault indication. It appears fault will stay cleared if you drive off immediately after clearing the fault indication or restart engine immediately after clearing but leave for 5-10 mins or more and fault re-occurs. Whats going on ??? Will contact ECU Testing to seer if they can explain, not keen on dragging the whole unit out again.
