srhutch said:
Marlon said:
The E85 (roadster) si Sport and the E86 (coupe) si Sport have the same N52 engine and suspension.
If you compare the pre facelift E85 (pre 2006) with the post facelift E85 si Sport then there are differences - suspension is harder and, as already mentioned, the engine has more bhp.
Not strightly true as some pre facelift have sport suspension.
OP, put you vin code into a BMW vin checker and it will tell you if you have sport suspension along with all other options fitted.
Ok, I'm confused now. Are we saying pre facelift M Sport equipped cars have a harder ride than post facelift M sport equipped cars or not?
Real Oem does list different part numbers for front & rear shocks between pre facelift M sport cars and the post face lift M Sport ones, which does imply they ride differently. However it could also be a result of the weight differences between the pre and post cars rather than a change in ride hardness.
