Monkeydonkeyratmagic said:TomK said:Monkeydonkeyratmagic said:Dropping sprung weight is far better for improving performance and handling.
You've got that the wrong way round.
From any on the number of things that pop up on google if you don't believe me...
"Racing teams thus reduce unsprung weight by, for example, using lightweight but delicate magnesium wheels, and engineers try to design suspensions with as little unsprung weight as possible. That’s why a few cars such as the 1961–75 Jaguar E type have employed brakes mounted not to the wheel hub, but to the inboard end of the half shaft: it’s all an effort to reduce unsprung weight.
Note that unsprung weight or mass is sometimes confused with rotating mass because some parts (tires, wheels, most brake discs) fall into both categories and because racers want to reduce them both. But they’re not the same thing. Rotating mass is what it sounds like, anything that has to rotate when the car goes forward, so for example the steering knuckle is unsprung but doesn’t rotate, while the half shaft is rotating but only partly unsprung. Lower unsprung weight improves handling and sometimes traction, while lowering rotating weight improves acceleration."
Be realistic and relative to the question.
What difference is a minor difference in weight going to have a 10+ year old Z4? f**k all is the answer.
Want a realistic option of improving handling, wrap wheels in some T888s. Stick to the road like a limpet.
Increase in acceleration? If it makes ANY gains over several runs £/s gained will be through the roof in a negative way.
There isn't much you can actually drop off this motor to make any substantial saving or gains. If you strip the seats for light buckets, change the dmf for a single mass lightweight job, lop the cat and back box off, you may then notice something.
Dropping a set of wheels on what is a relatively tanky and flimsy roadster isn't doing anything.
And all of these expected gains the internet raves about is assuming that all bushes, clutches, diffs and boxes etc etc are all mint.
Not trying to be rude or start an internet war but some of the stuff in this thread is offering some serious disappointment to the OP.
Appreciate your input. Trust me, I'm expecting nothing other than having nicer looking wheels in a lovely colour. I'm also happy in the knowledge they're going to be both stronger and lighter than the current MV3 wheels I have on.
Any gains I may or may not notice, well let's just call them a nice bonus. As I said this was more a curiousity than anything!
unfortunately they have to come from the factory in Japan, seems retailers rarely hold stock of Enkei wheels
