6. Concluding work and coding
This retrofit system requires coding.
- Connect the battery
- Encode/program the retrofit using DISPlus or GT-1 via path Retrofit/CIP
- Conduct a brief test
- Conduct a function test
- Re-assemble the car
The circuit diagram for the multi-functional steering wheel connection is available in DISPlus or
GT-1 if required.
ElegantSpoon said:Thanx wondermike
Just got in from a nice cruise round and the wheel feels completly different in a good way, Its much chunkier and is finished in a different material. Adds atleast 10bhp and in a odd way makes me drive faster :evil:
CJ you already had the MF buttons though didn't you? That might be the difference I'm going to call the garage that turned on the key functions for me to see if they can have a look but I don't know if its something you turn on in a menu or if you have to input code.
csmith starscream is a member and the non iluminated one cost me about £50 I think![]()
ElegantSpoon said:Hmm thats interesting! I will have to pop the airbag out and check if I pushed it in all the way and maybe look and see if the rest of the looms are in! There is definitely the pins in the socket to plug into.
ElegantSpoon said:I will look at the plug and see what's there cj if the loom is missing I might require some help on how to Reno e the various bits of trimI think I will make the looms myself if I can source the correct pins.
ElegantSpoon said:Haha you know so much its amazing
Well if thats the case I will order the loom if required! I thought knowing BMW it would be some stupid price. I was clearly wrong.
ElegantSpoon said:Sounds good! I've got the pins now so just got to get to the back of the LCM. Going to see if I can work out how.
There are no cables in pins 9/10 so hopefully once I've got this in it should all work ok![]()
ElegantSpoon said:Hey Phil
Seems we replied at the same time! The pins were males not feemale so I'm waiting for the loom to arrive from Germany. Did you use this http://www.maplin.co.uk/Module.aspx?ModuleNo=43076 sort of crimp to splice the new loom in with pin 21 & 27 on the LCM plug.
Thanx for all your help!!
ElegantSpoon said:Just an update incase anyone was considering this mod. I finially got round to sorting the buttons today, all you need is the loom mentioned above and some decent connections and it works fine!
Great Mod![]()
