GT Spec said:
///MBan said:
///MC said:
Hey,
I also recently installed a Karbonius Race airbox. Mine does not have the cut on the snorkel ( production August 2023) , i also had to trim it a tiny bit but as you can see from the pic, I kept the rubber part feeding the air from the grills and it lines up perfectly to feed the airbox.
I did previously have an eventuri intake, while alot of people will say it sounds similar to an airbox, it really isnt close, the airbox fills up the cabin with induction roar all the way to 8000 rpm. I actually removed my RPI mufflers just to enjoy the glorious induction noise.
Did you use a Dremel like GT Spec to trim the throat? And how did you work out how much to trim off - trim a bit off at a time until it fit?
I have one of these boxes on order and have to admit to being nervous about cutting it!
Where are you based? If you are fairly local I can walk you through it when you are ready to install it. Are you aware you need the earlier style rubber throttle boots? The later engines such as the ones fitted to the E85/6 had different boots from build. Let me know if you need part numbers etc.
Thanks for the offer, but I'm in Perth, Western Australia.
Thanks for the tip on the rubber boots - I actually bought a set of the Karbonius OE-style plenum I have, so I'm sorted there. I've also ordered the rest of the parts from Schmiedmann as well as the IAT harness from Turner, so I think I'm set!
However, always good for a cross-check, so this is my list of parts:
Part Qty P/N
CSL IAT Sensor 1 13629899008
IAT sensor o-ring 1 13621743299
CSL Crank Case Vent Hose 1 11157833649
CSL Airbox Air Shut Off Valve 1 11617833647
Alpha-N IAT Harness 1 Turner
rubber intake mounts 2 11617830735
Hose clamp - plenum side 6 11617830306
Hose clamp - throttle side 63mm 6 11617831745
Rubber intake boots 6 11612466477
CSL OE filter 1 13727838625
