Justino said:Hi GT Spec
the part number for the rubber boots would be helpful if you can provide so I can scope those out.
I put them in my part list above:
Rubber intake boots 6 11612466477
///MBan said:Justino said:Hi GT Spec
Justino said:Thanks, missed that - not cheap I see at £30+ each.
///MBan said:Agreed! Turner does a kit with silicone boots and jubilee clips that is much cheaper and makes it easier to change in the future. But, of course, it looks aftermarket.
///MBan said:I put them in my part list above:
Justino said:Finally done it - placed the order yesterday, circa 8 week lead time!
Any recommendations for the Alpha N remap - I am based in the Midlands?
I am assuming it will be ok to drive to the mappers after the intake is fitted as it will default to a 'stock' map in the absence of the MAF data?
GT Spec said:Justino said:Finally done it - placed the order yesterday, circa 8 week lead time!
100% contact Josh at Severn Tuning. He is based in the US but will map the car remotely using data logs and a final dyno session.
Justino said:GT Spec said:Justino said:Finally done it - placed the order yesterday, circa 8 week lead time!
Ideally prefer a one stop shop, ie have their own rolling road and map accordingly. Means I can get it done all in one day.
+1 for Arreve.SGRG said:Justino said:GT Spec said:100% contact Josh at Severn Tuning. He is based in the US but will map the car remotely using data logs and a final dyno session.
Recommend these guys for one stop shop: https://areevemotorsport.uk/
https://www.instagram.com/tv/CmZm6-FKjzj/?igsh=c3FpMmhoMXplejJl
Thanks for reply.maupineda said:The bracket under the filtered section maybe incorrectly installed, mine has no issue fitting that solenoid
The other solenoid for the brake booster feed just hangs.
2024 manufactured race box, comes with hole for push fit csl iatJustino said:I am waiting delivery of my box towards the end of the month - did yours come with no hole for the IAT sensor?
RedUn said:Had the car mapped today, curve and results all good until just over 6000rpm and then it pulls timing heavily, something like 17 degrees vs stock which is 27 degrees.
Anyone come across that before? IAT sensor was checked and scaled correctly?
Will PM you.Justino said:RedUn said:Had the car mapped today, curve and results all good until just over 6000rpm and then it pulls timing heavily, something like 17 degrees vs stock which is 27 degrees.
where did you have the mapping done, I will be in the same boat shortly.
