I'm after a bit of advice please..
The old Z4 (N20) is having an oil change and possibly brake fluid at a local garage (as I can't be doing with the mess and logistics of DIY) but I am planning on changing the plugs, pollen and air filters myself.
Is there anything I need to do specifically to change the plugs? I have a plug socket (14mm I believe) but do I need to check gaps on the new ones, disconnect the battery, lubricate the sealing rings, etc? I have never changed plugs before. The filters are easy peasy.
Ta very much...
Ta very much...
