Hi, so my E89 had new reluctor rings fitted to both sides at the rear last week, this resulted in new driveshafts being needed, ABS sensors and coil springs
. Today I have discovered a new oil leak, it is coming from the driver side of the rear diff, the flange the new driveshaft bolts to. I have contacted the garage that did the work and he claims that the driveshaft only bolts to that flange and the flange wasn’t removed/ disturbed as part of the work carried out, it would be an hours work to fix and the seal is BMW only. So my question is, how hard a job would this be, is it something I could tackle on my drive or do you need a special BMW tool to remove the flange, can I unbolt the driveshaft and simply push it to one side or does it have to come fully off
