Mr Tidy said:You're doing well with your history.![]()
I know keeper 7 of mine was a forum member and number 1 was BMW UK as that is where it had it's running in service!
It doesn't help that it has had 3 different plates either. :roll:
I've put my internal forum sticker in the driver's side rear quarter, but I've got the same glass as you so it doesn't exactly stand out.
Nice fresh grease on the bonnet catches should keep them moving freely for a while, but it's worth keeping an eye on them as the grease will also pick up dust and debris because of where they are.
If you haven't already performed surgery on your 2nd key you might find that if you used it a bit it would be revived - the rechargeable battery only charges when it is used.
I trying to use that key for driving to charge it up. I did have the metal section in contact with my tooth brush charger for about 28 hours and it still would not unlock the car. So new battery and programming it is.
