Nanu said:Really shocked and stunned that there is anything on the Yellow Peril left to upgrade?
Oh yes still plenty to go still…
Silverstar said:Yep getting to the subs is a right pain in the backside! I remember I had a room full or car trims and things when dismantling everything to install my subs. Regarding the fuse for the amp, couldn't you just use the right size cable put an inline fuse in and then get the appropriate connector from BMW to fit into that red junction box. That is what I did, there is a spare terminal handly just for this purpose:
B21 said:Silverstar said:Yep getting to the subs is a right pain in the backside! I remember I had a room full or car trims and things when dismantling everything to install my subs. Regarding the fuse for the amp, couldn't you just use the right size cable put an inline fuse in and then get the appropriate connector from BMW to fit into that red junction box. That is what I did, there is a spare terminal handly just for this purpose:
Having looked at it…the fuses you tapped into is rated at 40 amp and I need 50 amp…and the issue is the fuses are all fixed as part of the distribution board..
Silverstar said:B21 said:Silverstar said:Yep getting to the subs is a right pain in the backside! I remember I had a room full or car trims and things when dismantling everything to install my subs. Regarding the fuse for the amp, couldn't you just use the right size cable put an inline fuse in and then get the appropriate connector from BMW to fit into that red junction box. That is what I did, there is a spare terminal handly just for this purpose:
I got the female connector and blue cover part from BMW. The red distribution board, isn’t it just that a distribution board? Didn’t think it was fused.
Reamesy said:I think you need to tackle something complicated instead of just tweaking![]()
Jollyjoiner said:I wish there was a smilies for over the top of my head , my brain has gone BOOM![]()
B21 said:Jollyjoiner said:I wish there was a smilies for over the top of my head , my brain has gone BOOM![]()
Please look away now..as it’s going to get complicated when we get to real time analysis, time based correction, parametric equalisation and the effective use of Q and pros and cons of higher order slopes in designing high, low and bandpass filters![]()
Silverstar said:B21 said:Jollyjoiner said:I wish there was a smilies for over the top of my head , my brain has gone BOOM![]()
Blimey! Let me know when you get to fitting the blind spot monitor sensors.![]()
