I feel like I had my pants pulled down on the cost (£200!) but they are based next door to the garage and use full Hunter laser alignment gear. Given the readings before the alignment, I’m glad it was done.
Gulp, I was whinging last year when a garage charged me £102 for the privilege. Found a closer one that charges only £72. Both hunter/laser systems. Maybe I should stop whinging 😁
Least it'll drive better and stop scrubbing the tyres now!
Replacement rack fitted and all working well!
MoT passed with a small advisory on my front brake lines (slight kinking due to fitment of F30 Brembos. Requires tweaking on the chassis side).
4 wheel alignment completed and she drives beautifully! I feel like I had my pants pulled down on the cost (£200!) but they are based next door to the garage and use full Hunter laser alignment gear. Given the readings before the alignment, I’m glad it was done.
Here’s the before and after of the rear, just as an example:
View attachment 300493View attachment 300494
Congratulations Matt!
Nothing major this weekend — just fitted some locking wheel bolts to my E89.
When I bought the car a few months ago, I noticed it didn't have any, and I thought it was probably worth doing. I just don't want to come back to the car one day in a public car park and find it sitting on bricks! 😅
I went for the original BMW locking wheel bolts. I also made a short video showing how I fitted them, the exact set I bought, and the correct tightening torque, in case it's useful to anyone else. The video is in Spanish, but YouTube's automatic translation does a pretty good job and should make it easy enough to follow.
Interesting.
I’ve typically gone the other way and removed locking wheel nuts, due to past failures with deformed locking key. In the UK at least, the days of OEM wheels being stolen from older cars seem to be behind us.
Replaced the auto-dimming passenger wing mirror.
But decided to save myself £350 and swerve the monochromatic option and fitted one with standard glass.
Not so much the car itself, but I used Claude AI to create a full service record. I uploaded photos of the service book, invoices that have been passed on from previous owners, screenshots of the MOT history and locations. Vcheck details from before I bought the car.
It's pulled it all together, created an HTML page that has catalogued everything chronologically and shown me how it all marries up. It really illustrates the car story.
I understand this might come across as a bit nerdy lol.
Seems like the fun never stops!
I noticed in traffic that one of my angel eyes appeared barely lit. When I got out an checked, it was evident that some LEDs had failed. I’ve now purchased a new pair which should hopefully restore the appearance. I’m under no illusion that these LED replacements have a shorter lifespan.
I also changed my spacers following the alignment. Previously I was running 12.5mm front and 20mm rear spacers. This has proved to be too aggressive, with the rears kissing the plastic inner arch liner under compression. I’ve now put the 12.5mm spacers on the rear and put 5mm on the front, so going down 7.5mm all round. So far, so good.
I also changed my spacers following the alignment. Previously I was running 12.5mm front and 20mm rear spacers. This has proved to be too aggressive, with the rears kissing the plastic inner arch liner under compression. I’ve now put the 12.5mm spacers on the rear and put 5mm on the front, so going down 7mm all round. So far, so good.
I had the same last week. They were two years old. I have since replaced with these. Same make but much much brighter
NOVSIGHT H11 LED Headlight Bulbs,... https://www.amazon.co.uk/dp/B0DHS3NJ8K?tag=z4fo-21
Fitted the 3D printed cupholder that I'd retained from my previous E89.
The new 18i has the storage compartment package but I don't like the cup holders under the armrest so if anyone wants to swap them for the standard oddments tray please let me know.
Although it would appear that fitting the cupholder would disable use of the storage compartment between the seats I've found you can access it from the boot. Which is ideal for storing the air freshener and any other items you don't need direct access to from the cabin.
View attachment 300560View attachment 300561View attachment 300562View attachment 300563
View attachment 300565View attachment 300564
Well it seems perverse…but heh..it’s your car..I’d never be able to reach them with my joints…of course illegal to use whilst driving anyway…😳🙈😂
The lower cost rack fitted no issues?..did it need coding?
No issues whatsoever. Working perfectly and feeling fantastic with the new track rod ends and full alignment. No errors but I know I need to code it to my car to ensure the config is correct. I’ve seen how to do it with Protools but need to buy a licence. With the costs of the rack, fitting and alignment being chunky, that’ll have to wait till next pay day.
Admittedly I should have done the lower M3 arms beforehand/the same time but couldn’t stomach the additional cost at the time. I’ll be doing them next and getting the front alignment checked over.
A few folks have used these guys all with good results…👍
The steering rack refurbishment place?
For £269 and no original unit returns, it’s an absolute steal. I was sceptical but it all seems good and had replaced gaiters. They talk the talk when it comes to the refurbishment process but I’ll never know how much of that they actually follow. I’m hoping that they rectify whatever the original issue is inside the control module and that it isn’t just a blow over with some paint and new rubber boots.
