My 35is is sitting down at the rear. The Ohlins ride height suggested is 367/367..against original of 378/367 mm.
Current set up is lower than that by some way.
Two compounding issues..
Ohlins only does one kit for all E89s..
28i manual is 1,750 kg with 47.3/52.7 distribution = 922 kg on rear (front 828kg)
35is is 1,895 kg with a 49.3/50.7 weight distribution = 960 kg on rear (front 935kg) and you wonder why the 35is doesn't handle as well as a N20!
In addition I carry a full size 326M front wheel in the boot when touring = 22 kg and toolkit = 10kg
Plus full fuel
And almost ALL the time roof down when hooning!
That's about 50kg or roof moving back say a metre
So with some bags and a full tank of fuel (BMW weights are zero fuel)
So the rear weight is over a 100kg more than a 18i/20i/28i on the rear wheels ie about 10%
In addition I'm going up to 245/40 19 and 285/35 19 onm my 437M wheels.
The 70nm rear Ohlins spring is jacked up about as far as it can go.
My 96 nm/mm rear springs arrived today from the States! Stock Ohlines in 70 nm/mm
Just discovered that Eibach do a whole series of these springs in various rates 60/79/88/96
https://www.eibachshop.co.uk/pages/eibach-racing-spring-catalogue
Going to fit these Eibach babies to help wth adjustment and reduce 'twang' and 'boing' from the springs.
We'll see how it goes..now I found the Eibach catalogue I can go to an intermefiate spring rate if required!
