I had an issue with one of my brake carrier bolts backing out…maybe caused by the stress of the uprated rear brake, maybe cause I didn’t use the old caliper cradle bmw bolt which has some primitive antilock washer fitted..maybe because I’d remounted the caliper cradle several times the loctite had worn off..
So using these fancy nord lock washers in super harden steel..arguably the best anti vibration washer…
Fresh 10.9 high tensile bolts…double locked the through bolts..
Did try the wire lock strategy but close to impossible to drill the bolt heads to allow the wire to be threaded..
Lots of medium strength loctite this time..
