Angelus666 said:Is there any system which gives a comparable noise to the 981 GTS...?
http://youtu.be/WRoxpUN8rs0
mr wilks said:For anyone following Nige (BCS) has asked if i can go over mid Sept to have a set of the "Prestige" boxes fitted for a trial period , try out for a few weeks then decide which ones to go with ?
Ive really settled with the current Sport boxes though & if the others are much quieter i think i will opt for the Sport as the keepers
pHilli0 said:mr wilks said:For anyone following Nige (BCS) has asked if i can go over mid Sept to have a set of the "Prestige" boxes fitted for a trial period , try out for a few weeks then decide which ones to go with ?
Even if some people may not love the sound from the clip, the forum has to be thankful for your effort for this and lots of updates.. over a long period. Creating new boxes isn't just a 5 min job so cheersOnce everything is settled they sound like two options as an alternative to the rest of the market at a similar price.
zmaster007 said:mr wilks - do you find that bits of trim/loose change vibrate when you use mid throttle at 2-3k?
mr wilks said:zmaster007 said:mr wilks - do you find that bits of trim/loose change vibrate when you use mid throttle at 2-3k?
Nope , nowhere in the rev range in any gear gives off any vibration & for the record , my car has no loose trim![]()
Taz said:when is the other box being fitted?
zmaster007 said:mr wilks said:zmaster007 said:mr wilks - do you find that bits of trim/loose change vibrate when you use mid throttle at 2-3k?
The lack of roof means everything wobbles together![]()
. And in your opinion, how loud is the cold start? Loud enough to irritate neighbours in the morning?
Taz said:i thought maybe you would be fitting then next week
any ideas how long you will try the new box?
