Is high and low beam both from the outer bulb? The inner bulb is only ever a dim ring - is that how it should be? Full beam wasn't working and I was getting flashed with lights on low beam so I disconnected the battery for an hour to see if that would reset the lcm and the shutter seems to work now but the inner bulbs are still dim. I came from a non xenon 3.0si and I think the inner bulbs were the low beam on that which has me confused!
