Gauss said:Involves shortening the lifespan of the engine IMO.
Giles said:Gauss said:Involves shortening the lifespan of the engine IMO.
No it doesn't, you trolling twat. Why don't you try to contribute instead of posting like the child you are?
To OP - I will dig out the relevant SteveD commentary and post as soon as I can locate it![]()
Fair point actually.Gauss said:But the engine isn't the only part of a vehicle, there are other parts that need to break in too.
Giles said:Nice one Jay.
I'm still frantically searching across other boards for Steve's original post![]()
Who is SteveD?JayD said:From what I recall as the post no longer remains, the key to Steve's running in procedure is in the first 200 miles from new.
A series of taking the car up to maybe 7000 rpm on several progressive runs, in a straight line so not to put strain on the diff. Once the top suggested rpm is reached allow the car to rev down to 2-3000 rpm and repeat this procedure several times over several occasions during the 1st 200 miles. Always do this with the engine nicely warmed up.
Theory is this will assist in ensuring that the piston rings seal nicely in the chamber, additional speed through the increased rpm will help smooth the chambers nicely, much like sand papering something more quickly to get a smoother finish, resulting in a good tight engine.
First two hundred miles is the key, not much point thereafter as the piston rings will have sealed as best they can.
Good article here:
http://www.mototuneusa.com/break_in_secrets.htm
peppernick said:Who is SteveD?
Top pup said:peppernick said:Who is SteveD?
A serial M series owner and the reason all the Z4MCs have got CSLs, Aero skirts and strut braces.
SteveD Z4MC thread
PeteH said:Top pup said:peppernick said:Who is SteveD?
SteveD Z4MC thread
and PS2's![]()
enfield said:You also have to bed the brakes. Do you remember that procedure??
