Z4M-2006 said:John
What are your thoughts about fitting on a normal road car ?
Is engine feel and noise transmitted through the chassis ?
My thoughts on mods are that, if you don't think you've got a problem, then you've got nothing to fix. I would say that there is virtually no increase in NVH when idling when parked and none when driving.
I think that the stiffness to the front suspension that the V-T engine mounts adds, will help to redress the gross imbalance that I see F <-> R with the OEM suspension, so I would expect that this would be a good and relatively cheap upgrade to an otherwise OEM suspension set-up. As soon as I drove my car up the road today for the first time with the engine mounts, it had a similar feel like the first time that I drove my Z3MC with H&R ARBs. The H&R ARB upgrade is now acknowledged as THE most cost-effective upgrade for the Z3MC and I would wager that the V-T engine mount upgrade will, in time, be considered THE most cost-effective upgrade for the Z4MC. Controlling lateral bodyroll really does make handling so much better.
However, the reason that I did this mod was to attempt to improve the gearshift problem I've had, and I think it will be only after another trip to The Ring that I'll know if this mod is the answer to gear-shift denial I experienced, but I am optimistic on this front. The benefit to the handling isn't altogether a surprise to me, but it has been much more pronounced than I expected and is warmly welcomed by me. Had I known the improvement to handling this mod has, then I would've done this before now.
I think Beedub is right to rave about this mod and I have to thank him for bringing this mod to my attention!
