A mate of mine here in Australia broke the gearbox in his Z4M 18 months ago. He's been searching for a replacement ever since but as there are such a small number of of Z4Ms here he's had no luck. The box is a GS6-37BZ-TJEE
He tried to get it repaired but in the process the rear case shattered and log story short we no longer have even the broken gearbox.
We found a GS6-37BZ-TJES from a 2006 E87 130i and from doing some cross referencing on realoem most of it checks out. Output flange is the same too. The only unknown is the input shaft - the guy selling the gearbox doesn't think it will work. The Z4M has a model specific clutch plate, but it may just be because it's a larger diameter than the usual clutch plate used on the S6-37. On most other BMW engines of that era the input shaft bearing is incorporated into the flywheel but on the S54 this bearing is in the end of the crankshaft.
I've found a discussion where a guy retrofitted an E46 330i transmission (GS6-37BZ-THEB) to an E46 M3 (I don't know why he didn't just modify his SMG box to manual?!) and he claims he needed a different clutch, flywheel and starter! That gearbox has two letters different in the variant code though, so it may be much more different.
So I thought I'd post here in the long shot that perhaps somebody knew more about this than we do. If we still had the original gearbox it would be an easy process to just put them side by side and compare...
Alternatively, does anybody have a spare Z4M box laying around they would ship to Australia?
