Yes I know it has a oil temp gauge, but normally the oil temp sensor sits in the back of the oil filter housing. The S54 only has an oil pressure sensor, and the other hole is a blank (I saw that on another forum where someone installed another sensor and I asked where because I thought both holes would be in use but it appears its not).
The coolant sensor in the return pipe is named "oil/water temp sensor" but it sits in coolant.
Maybe there is another sensor that also measures temperature but is not listed as such?
Erratic oil temp is strange. There is of course a cooler and thermostat (also for the oil), but its a very straightforeward system. I dont know if it has problems with trapped air. But keep a good eye on the oil level if the temp is erratic. No oil pressure can get expensive... There is of course a light for that too, but that can be broken.
However the oil temp gauge (and in normal bmw's the water temp gauge) are 'dampened gauges', so the temperature displayed is not the actual temperature. It has electronics that evens out the actual values. (tbh I dont like those systems because it doesnt really tell whats going on)
