Beedub said:OP i think you will REALLY enjoy reading through this, some great info and great pics too, may be worth registering and posting some questions to andrew lang,... The op in this link is at 200K on the original cams and followers, the wear on some of them visually flat.
http://www.m3forum.net/m3forum/showthread.php?t=547883
Good read thank you. Looks like the lifter against cam is a common problem but nobody knows the cause which is a worry
Mine is currently having the valve clearances adjusted because they were all miles out when he measured them and haven't been done for a "very long time". Suprsingly on closer inspection he says my current cams might be ok and sorting the valve clearances might fix the car but I'm not as optimistic as him so I've ordered a set of Schrick DLC followers in advance.
