Z4 Wheels but no Z4 thread
poss
My newly-purchased merlot 6 speed manual 3.0i is in the only state of Australia that is more COVID-ridden than my patch - so collection has been problematic.
In the meantime I am amusing myself by refurbishing some 19" rims to adorn upon her long-anticipated arrival.
Have decided to do them two-tone - Gun Metal Grey on inside and BMW Wurth Silver on the spokes.
Gun Metal Grey coat applied tonight (I used Duplicolour metallic Gun Metal Grey). Impressed with the result so far. Will keep updating this thread as I complete the wheels and, finally hopefully, get them on the car!
It's a shame you can't collect your car, but I'm looking forward to seeing how your wheels turn out. :thumbsup:
First coat of the Wurth silver on the spokes. Far more difficult to get a good coat than the duplicolour grey on the inside barrel - the can definitely needs at least 3 mins of shaking and spray distance is more fussy. After leaving a few hours to set a light rub with a scotchpad brings it up nicely ready for the next coat (not finished that yet btw).
Starting to look like a real wheel now!
Wheels are just the start - Here's the rest of the immediate list of parts:
Item Quantity Inventory Detail Description Rate Options Tax Amount
Kidney Grill - Chrome - Right - 51137051958 1 Kidney Grill - Chrome - Right - E85 E86 Z4 2.5i, 3.0i, 3.0si, Z4M 68.99 Yes 68.99
Kidney Grill - Chrome - Left - E85 E86 Z4 2.5i 3.0i 3.0si Z 1 Kidney Grill - Chrome - Left - E85 E86 Z4 2.5i, 3.0i, 3.0si, Z4M 68.99 Yes 68.99
VANOS Cover Gasket, Elring - E46 E39 11361433817 2 Elring VANOS Cover Gasket - M52TU/M54 3.59 Yes 7.18
Upper Inner Bushing, Powerflex - E36 E46 E85 PFR5-4617 1 Powerflex Rear Upper Control Arm Inner Bushings - E36, E46, Z4 63.74 Yes 63.74
Powerflex Sway Bar Bushings - PFF5-4602-27 1 Powerflex Street-Series Front Sway Bar Bushings - E82, E46, E9X, E39, Z4 56.09 Yes 56.09
E46/Z4 Non-M Front Suspension Overhaul Kit - Stage I 1 E46/Z4 Non-M Front Suspension Overhaul Kit - Meyle HD & Powerflex Street 312.95 Yes 312.95
Powerflex Subframe Inserts - E46/Z4 non-M 1 Powerflex Rear Subframe Inserts - E46 323i/325i/328i/330i, E83 X3 (Street Set) 135.98 Yes 135.98
Rear Shock Mount (RSM), Powerflex - E30 E36 E46 PFR5-5630-10 1 Powerflex Rear Shock Mounts (RSM), 10mm Stem - E30, E36, E46, Z3, Z4 108.79 Yes 108.79
Rear Camber Arm Outer Bushings, Powerflex - E36 PFR5-4618 1 Powerflex Rear Camber Arm Outer Bushings - E36, E46, Z4 70.54 Yes 70.54
KONI Sport (Yellow) Shock - 8741 1450LSPOR 1 KONI Sport Front Left Shock - Z4 2.5/3.0 230.64 Yes 230.64
KONI Sport (Yellow) Shock - 8741 1450RSPOR 1 KONI Sport Front Right Shock - Z4 2.5/3.0 230.64 Yes 230.64
KONI Sport (Yellow) Shock - 8240 1208SPORT 2 KONI Sport Rear Shock - E85 Z4 2.5 3.0 3.0si 181.04 Yes 362.08
UPS Worldwide Expedited® 1 UPS Worldwide Expedited 282.44 282.44
Total $1,999.05
Order acceptance is pursuant to BimmerWorld's Terms & Conditions, available online.
Silver top coats done (4 coats all up with sanding in between). One last light sanding and ready for 2-pack clear coat to really make it pop.
225 Wheel Toprcoat.jpg done:
