Beisansystems provides really good instructions for vanos seal replacement:
http://www.beisansystems.com/procedures/vanos_procedure.htm
Z4 model makes little difference for the job. I can write some things i found out during the vanos overhaul:
My top tips for Z4 vanos project
-Remove radiator fan for more room, ( top cover off, 1 connector, 1x torx 1x push rivet and pull up)
-Remove a/c & water pump serpentine belts (not mandatory, but you avoid contaminating belts with oil or coolant) DIY videos from youtube
-Remove coolant sensor from bottom rad hose and drain approx 1.0 litre coolant from there (1 connector, and push clips and pull) Remember to buy new o-ring for sensor 13621743299
-Remove bottom coolant hose from thermostat housing (unclip, then pull from hose gently)
For vanos removal in Z4 you will need following special tools:
-90 degree angled pliers
-8mm stubby hex keys or short hex bit for ratchet
If vanos would not clear from engine bay, there is 3 different styles to do it.
1. Loosen that bulkhead bolts and use piece of wood to manipulate that agains water pump pulley to make more room.
2. Lift engine up first and remove engine mounts, then lower it enough to remove vanos
3. You can also remove those stud bolts from head with lock pliers or similar..
Remember, read Beisan instructions carefully, this job takes time..
