DHK said:Hey did anyone track their 452s ?? Are they any good for the track???
0400Runner said:Thanks Mike...BTW, the sticker on the driver's side door panel says 30 psi both F & R. Should the psi change since I changed the tires from RFT to non-RFT?
007-Z4 said:Hello Friends,
Thought I would give you a update on my Falken FK 452's----After 2K miles, they are just fantastic, no uneven wear, rides is so smooth and well controlled, in the rain they are sticky![]()
Final rating to date *****stars
The only concern is If I get a flat tire, Has anyone ever used the BMW repair kit?
Happy Holidays!!!
Bob
Pom said:so let me get this right - if i have an 05 3ltr then i will have the ABS system not TPM (im in Aus).
My tires are also coming up to needing to be changed, looking to not replace them with runflat as in aus that will cost me approx $2400 for just hte tires... i also hate the ride (and the grip in the wet, would like something a bit more grippy)
was looking at some goodyear asymetrics or the falken's
paddy wright said:dont you worry bout wheel damage wth reapair foam?
