caius said:
Yes, I think so. I ended up epoxying mine to repair it, from memory the two parts separate so I could repair it (used masking tape to mould it, then poured the epoxy in. Seems to have worked so far.) The hinge "clips" can be popped out, so you put the two parts together, then push the clips in to turn it into a hinge again from memory.
I am confused! Your repair seems IDENTICAL to the repair that I wish to do, other than I am planning on repairing the cylinder part of the hinge with the broken off piece, glue and plastic welding, not epoxy like you did. But I am am still unsure of a couple of things in terms of putting it back together... see diagram at top of this thread -
https://z4-forum.com/forum/viewtopic.php?t=79822
The pin part of the hinge is two pieces, 10 and 12 on the diagram, that push together and seemingly once they are together they cannot be removed without destroying them. I think the process is -
(1) Cut off the pin numbered 10 and 12
(2) Repair the cylinder
(3) Use new bits 10 and 12 (or some sort of DIY substitute) to create a new pin
(4) Connect glove box to backing
(5) Screw backing to car whilst the box is tilted forward almost touching the floor
(6) Fold up box and connect all the other bits up.
An alternative might be to -
(1) Leave the pin numbered 10 and 12
(2) Connect glove box to backing as best as possible
(3) Repair the cylinder around the pin
(4) Screw backing to car.... etc etc
But I am still not 100% sure that the backing can be screwed back on whilst the boc is attached to the backing! Can it?
