What have you coded with Carly
Running the lite version from an Android with a bluetooth conection:
https://www.amazon.co.uk/gp/product/B01C55RY4W/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
It allows me to connect and run diagnostics (where you can email the results as a pdf), before I buy the full version I'm assuming that if I can do that full functionality will actually work? I keep reading you need to run android from a cable and it's an expensive mistake to make if it doesn't work.
Alternatively you could just reset it now and once again when its serviced. Its easy enough to do through the clocks.
No idea as I run iOS... I didn't want to risk it as I've heard you can run into problems with a universal adapter. So bought the adapter from Amazon? Think that's where they listed it, direct from Carly. But again different experience as I'm on iOS. Could be a completely different situation with Android…
So long as it's managed properly, otherwise it could give you a false indication of your true service interval, and you might not realise till you've done (for example) 3000 miles over your service mileage.
Think it's all sorted tho as Matt_3.0Si only had it serviced a week ago, so a weeks worth of mileage is negligible :thumbsup:
On my side I've managed to remove the warning light error for parking lights deactivating the monitoring tension/voltage.
Other than that I've failed miserably to activate autmatically lock the doors when driving at 8km/h, I guess it needs to be activated alonside another setting but I am afraid to mess around with other "lock" functions. Any advice?
Other than that I plan to include the following to the list:
- Comfort open windows using remote
Windows go down on fob unlock (and hold)
- Comfort close using remote
Windows close on fob lock (and hold)
- Automatically lock vehicle
If I've unlocked the car by mistake and not opened a door the car locks itself again after about a minute
