What have you coded with Carly
Gstew89 said:
Are you guys all using the Carly app on your mobiles? Is the bluetooth connection just as good as a cabled connection? Also is the coding pretty straight forward to complete?
I use it on my iPad with a Wi-fi obd thingy, it’s self explanatory really & simple to navigate through :thumbsup:
Claret said:
But why..............are all these REALLY necessary?
A strange question. None of the coding options are REALLY necessary, but it's about customising the car to your liking - no different to aftermarket wheels, replacing a whippy with a stubby (God's work), Halo headlights and so on....
I think it's all changed now anyway. It's now a subscription service, so you have to renew it every so often. Maybe worth taking a look here to see if you can find anybody local with the app? Then you can see whether it maybe a good investment for you.
Yeah it's a subscription if I remember rightly. I got it not long back. It's good fun swapping and changing bits. I'm sure there must be someone local to you?
Cheers, there are a couple of folk not to far from me thanks for the tips
Quick Carly question for a noob; does the option exist to code-in '3-flash indicator'? It's a function I really miss from my previous cars (my '04 645ci had it, was a little surprised when my '03 Z4 doesn't). It would appear a previous owner has used Carly in the past as my car has a lot of the coded options that have been mentioned on this thread.
It’s not possible with Carly. Not on the pre facelift. Maybe possible with other, more advanced programs like NCS.
Changes will probably concentrate on the newer models. Doubt any coding parameters will change on the e85 or e86 Zeds
Anyone know if it's possible to mess around with the service indication system using Carly?
My service indicator has been out of sync for ages - says it's due an Oil Service when it's due an Inspection, and vice-versa. I'd be interested in getting it sorted.
Car is an E86, so facelift.
Important to do it at the service tho, otherwise you’re going to mess up the service mileage intervals.
Ah, cheers guys - I assumed you had to do it through diagnostics. Only had the car serviced last week, and it only really gets driven at weekends, so perfect timing :)
