Robsterrob said:Just a bump on this....I am finding I'm getting stone chips on the inside of wheel arches (where the red paint meets the black plastic) and some road rash along the side of the car at the rear of the arches.
Robsterrob said:I was getting increasingly frustrated at finding more stone chips in the wheel arches, and having a custom set of guards made was cost prohibitive, however, I had a flash of inspiration, and had a look to see if anything similar was available for a Toyota Supra - and there was!
They needed a slight modification - one fixing hole was in the wrong place at the front, so a simple drill was all that was required, and I had to reduce the height of the spacers on the rear.
I think they look OK.
Robsterrob said:That's the ones....need ever so slight modification (to the flaps, not the car) - you'll need a drill and a hacksaw. Pretty simple though.
ori said:When you get it, could you post what you needed to do to them and maybe some pictures on how it affects the look of the car?
Swiftly said:ori said:When you get it, could you post what you needed to do to them and maybe some pictures on how it affects the look of the car?
Will do![]()
Swiftly said:I've found a UK site thats selling them, they would certainly help stop some of the stone chips that's appearing on mine
Swiftly said:Robsterrob said:That's the ones....need ever so slight modification (to the flaps, not the car) - you'll need a drill and a hacksaw. Pretty simple though.
I've ordered a set, there're not cheap but if it sorts out the stone rash that's starting to form on the leading edge of the sills and rear bumper, then it will be more than worth it.
Argyll Andy said:Swiftly said:Robsterrob said:That's the ones....need ever so slight modification (to the flaps, not the car) - you'll need a drill and a hacksaw. Pretty simple though.
Nick, did you get these and if so how much fettling was required to get them to fit?
Andy
Swiftly said:Argyll Andy said:Swiftly said:I've ordered a set, there're not cheap but if it sorts out the stone rash that's starting to form on the leading edge of the sills and rear bumper, then it will be more than worth it.
Andy
Andy, the wheels will need to come off, but the whole process only took me over an hour to complete. The kit contains everything you need. The front stone flaps were the easiest to fit, but you will need a drill as I found the top 2 holes didn’t line up with the pre drilled holes on the flaps. I reused one of the old shorter plastic rivets to temporarily locate the flap in place so that I could mark the new locations for drilling. Removed flap and drilled 2 new holes, then refitted using the new slightly longer plastic rivets which are a perfect fit. Each of the rear stone flaps come supplied with 3 screws and 3 plastic collars which act as spacers. The plastic collars need to be measured and cut to size with a hacksaw, so measure twice and cut once! I will try and take a couple of photos of the rears when I clean the car tomorrow.
Swiftly said:Argyll Andy said:Cheers Nick, I think I’ll just order a set. Any further pictures appreciated![]()
Rear flap
