ben g said:Measure standards and add the spacer width on? Iirc they are m12x1.5 bolts standard, 26.5mm long. May be wrong though.
ben g said:I just typed in bmw z4 wheel bolts on ebay and it's definitely 26mm (thread size) Unsure about the 0.5mm, not that it would make any difference, it's so small. So add 26mm to the size of the spacer and buy them.
Bad_Pritt said:ben g said:I just typed in bmw z4 wheel bolts on ebay and it's definitely 26mm (thread size) Unsure about the 0.5mm, not that it would make any difference, it's so small. So add 26mm to the size of the spacer and buy them.
So for anyone looking for spacers on a Z4 E85:
120x5 (72,5mm)
bolts; M12x1,50 26mm standard thread size + spacer width
Measure your max width: take a bar or straight wooden beam, put it upright against your wheel arch and level it. Then measure the difference between your rim/tyre and the wooden beam (to avoid that your rims stand out). If you are thinking of dropping your car, you should consider smaller spacers.
Now I know what to look for. Thanks guys
I'm going for 12-13mm front and 15-16mm back (as I want to drop the car 35mm too)
I'll post some pics as soon as I get it done... I'l probably color the brake calipers red too![]()
LukeMace said:Bad_Pritt said:ben g said:I just typed in bmw z4 wheel bolts on ebay and it's definitely 26mm (thread size) Unsure about the 0.5mm, not that it would make any difference, it's so small. So add 26mm to the size of the spacer and buy them.
120x5 (72,5mm)
Good info Brad_Pritt
Looking forward to pics!
Craigza said:Been watching this thread for a while... Since lowering my car 35/40mm all round my 108's seem swallowed by the car.
Just ordered 25mm rear spacers as I'm after the wider rear look, will post pics as soon as I take delivery!
Also treated myself to some pressed metal plates. :roll:
Craigza said:If they stick out they will be sent back and traded for 20mm, I've had a few people look at the car and they recon 25mm should be spot on BUT we will soon see.... (they have gone in further since lowering)
I will have them fitted on Wednesday anyway and will take pictures regardless of if I keep or send them back!
I've only got the one picture of my car lowered as of yet.... as seen below.
**EDIT** I Should probably mention the car has now settled and sits slightly lower.......
Craigza said:In my opinion its a massive improvement on looks when the wheel arch gap is closed, this is how the car should of come out of the factory!
I had a local BMW specialist fit my springs, bit of a price break down for you:
£180 for H&R lowering springs
£220 for fitting and hunter alignment.
Total = £400 - which is just over 500 euros so that price you were quoted seems spot on!
I also recently fitted PowerFlex wishbone bushes which was a nice addition to improve handling, was about £100/ 125 euro for parts and labour.
Marf83 said:Hey, I'm about to fit Eibach' on my Z4R with 108's. Has anyone got the same set up & fitted spacers? Got any pics? Thinking of doing both at the same time.
Bing said:Marf83 said:Hey, I'm about to fit Eibach' on my Z4R with 108's. Has anyone got the same set up & fitted spacers? Got any pics? Thinking of doing both at the same time.
I'm going book mine in this week to have my Eibachs fitted in early August, and I am going to do the same I think. Be rude not to really - wheels will be off anyway, and only one alignment session necessary![]()
Sorry, not got pics though... Obviously :roll:![]()
T2FFN said:Dont need to get alignment done after fitting spacers, so no need to wait.
