Try reading the info from the link I posted.Nanu said:Keyless start was not available I think when I bought mine in 2014, hence it has comfort access which is all part of the comfort package but does not include the keyless entry.
Comfort pack and comfort access are two different things.Stevo1987 said:Try reading the info from the link I posted.Nanu said:Keyless start was not available I think when I bought mine in 2014, hence it has comfort access which is all part of the comfort package but does not include the keyless entry.
Ole gits rule said:The key fob function is not working so will be hooking up the laptop tomorrow to check that out - quick question, if the battery is struggling will this stop the roof woking off the key?
Ole gits rule said:May put the batt charger on it tomorrow if it is fine (no garage) and see if I can boost the battery
Ole gits rule said:I think I can get one of them, can get very close to the sun room / study and run a cable out, do you use a trickle charger on the car and leave it running all the time?
ronk said:My smart charger goes on a maintenance charge at the end of October until April and sits at 13.6volts
Ole gits rule said:ronk said:My smart charger goes on a maintenance charge at the end of October until April and sits at 13.6volts
Going to get this sorted, my boy can rig the electrics and get most of the bits from work![]()
Did you sort it? I recently installed Smarttop, the setting for remote is:Ole gits rule said:Smart Top now fitted, wing mirrors now closing on the key, which is really good![]()
One touch roof operation functioning off the internal buttons![]()
OGR
mr.tourette said:Does anyone sometimes get the alarm going off when putting the roof up on the remote with this.. Ive had it a few times but not sure if I'm holding the button down too long or something
It is an odd one.. doesn't happen every time so im wondering if im setting off some kind of panic system by holding the button too long. I think some kind of panic alert can be coded in and I've wondered if ive triggered that as the alarm shouldn't be live at that point i thinkSmartbear said:mr.tourette said:Does anyone sometimes get the alarm going off when putting the roof up on the remote with this.. Ive had it a few times but not sure if I'm holding the button down too long or something
Not had that myself.
