MaxSheperd
5) On the left rear wheel arch within the boot area under the panels is a earthing point with mutiple slid on crimp points, just run the neg to this point with a spade crimp on it.
Is this below what you were talking about? This is a picture from the car with the 676, but no reason to think there is not one in the other car without 676 as I can see so many ground cable there.
6) There is no ASD in the 35i, as per other reply. So that's why I sent you the diagram without the ASD in the line, so as to not confuse you
Some wiring colours did change over the years, alas you don't get this from NEWTIS diagrams. Don't worry about the colours, just compare the positions, that's the important point
Can I ask you how you know that the 35i does NOT have the ASD, I cannot manage to figure this out by looking at the newtis. :/ I Must say having a car with the 676 system I want to retrofit helps as I will basically mirror this into the other one.
But yes I am looking for consistency. Colours are just arbitrary.
7) I realised that the footwell subs in the front left and right receive from the same pin at head unit. The cable split in door speaker and subwoofer at locations below, so I will cut the cable there I think and seize it. I will then connect the front subs to the wire coming from the amp. However, from the diagram it is clear the the front subs share the same channel. So I think that I will split the cables coming from pin 41 and 42 at amplifier level in two branches just in the boot. One which will go at left front sub, the other branch to the right front sub. This latter will probably be the only wire which I will pass through the driver side, as to avoiding butchering around the drive dashboard. Might be tricky.
8) Finally, I made a conversion sheet for the existing wiring (see below). I would appreciate if you would be able to go through it and cross compare it with the diagrams. It might take some time to go through it. Just an extra pair of eyes wont hurt
thank max.
thank max.
