AnubisZed said:Silverstar said:Dave I have the factory standard subs with enclosures here should you want them, I can do a very good price if needed. But I would have to question going down this route, at the end of day you will have a factory standard system which is limited in performance and going the aftermarket route as I have done in mine will yield better results with less complicated install.
Thank you![]()
See now this is my quandary, if I go the OE route, yes it's a lot of work in theory, but at the end of the day it's OE, which is what I like to see. But if I go down the aftermarket route using the Vibe amp then it's straightforward plug-n-play, a couple of tweaks and you're done. It's also hidden away so you don't see it, even the matching sub is under one of the seats (it's a slimline sub).
Now I don't have a big issue with my system since I retrofitted it all, in fact I think it's very good quality, my issue is when the roof is down I'd like to be able to hear it a little better, nothing too grand, just enough, after all I'm driving with the roof down so I'm not expecting it to be full beans clarity. With the roof up and playing good music mine is a very decent system with a good level of sound already, I can hear it, I can sing along (NO, no videos will be provided on my channel) and I enjoy it, especially when compared to the God awful quality from the base system that was in it to start with.
So this is a lot cheaper without the hassle, simply plugs into the headunit and you don't have to run any extra wires...
Are you sure we can't entice you to make a sing a long video?
