Liam-O said:mines a Nov 04 model.
Is it 100% guaranteed that ill need to buy the extra parts? Is there and easy way to check this out?
helloDavid.f8 said:Hi from a newby who has just aquired a Z4 and would like to add the cruise control option. Is it simply the case that you add this control stalk and thats all, nothing else ? Can it be that simple ?
David.f8
Spooky said:Completed the cruise retrofit last night, It went like a dream, Every part that I had to disassemble/reassemble went in with a satisfying and positive CLICK!
If anyone else is thinking of cruise and has a post '04 plate with a M54 engine, I will happily try to answer any questions you have on this install.![]()
tannera34 said:Just to say I have a 08 Z4 2.5 SE. I retrofitted the cruise control. It took time (3Hrs) but was easy. Bought my stalk online with wiring loom for £80. Bargain.
I use it all the time on the motorway and wonder how I got by without it.
However there is an important issue:
The BMW instructions are WRONG about the socket and pin the cruise control wire goes into in the engine management electronics. A cynic might suspect foul play here. Surely they would not lie to ensure they get extra money.....
NO ECU CODING IS REQUIRED It works straight away if you wire it right.
There is a post or link on this website to a chap who did a write up and gives the correct socket and pin address, seek it out before you start. And to the gentleman that did write it up - thank you very much.
