TONYMOR said:Driving this morning roof up and red roof symbol appears on dash along with the gong sound. Disappeared then repeated again then off . Any suggestions?
Strummer63 said:This happened to ours earlier this year. E89 2013 model.
At first just the red warning light (usually just after setting off) then the roof operation intermittent failure.
Main dealer struggled to find cause as no fault codes shown and problem never occurred whenever they drove it. :headbang:
On a hunch they changed two microswitches and been fine ever since.
TONYMOR said:Battery checked and Kwik fit said battery fine car needs a good run . Happened to need a 30 mile drive that day all was fine. Two days later problem raised itself.? Auto electrician I suppose or another battery check elsewhere as I can’t see doing a lot of distance driving for a while with COVID circumstances?
Trickle charger helps up to a point but frustrating not to find a definite answer?
maxman said:If it is a hall sensor,the 1series convertible is the same ,but cost a fraction of the price.Someone posted this a while back..How old is your battery?
