dans6490 said:You could possibly guess at 300 grams but it is a guess until they're made.
GuidoK said:dans6490 said:You could possibly guess at 300 grams but it is a guess until they're made.
I played around with some 300gr objects and indeed it's not that heavy. I don't think the extra weight will hurt the plastic on which it's mounted with vibrations. It's a large area with 3 point mount so not that weak.
But if Jingle wants to part with his original rpi scoop for 72gbp that sounds good to me too![]()
Is it still at your place (so you can ship it) or do I have to sort that out with Jingle?
Yes I want them both; the rpi scoop and the skidplates pleasedans6490 said:GuidoK said:dans6490 said:You could possibly guess at 300 grams but it is a guess until they're made.
Yes, I've still got it, I can send it with the skid plates, if you still want them. Would need to check on postage costs.
SamUK said:when are these coming in? just a rough idea?
cossie si said:If it's not to late, could i have an air scoop in black please! I'll send the money whenever you require it! Great job btw!
PerryGunn said:![]()
Quick question - from the instructions, it appears that these will require some self-tapping screws. Anyone know what size?
dans6490 said:PerryGunn said:![]()
They come with 19mm self-tappers. The hole is 3mm wide. I was going to look into getting some and sending with the scoops.
