E85 - 2004 - 3.0i
Having just got the car on the road after massive effort and expense she's now decided to stop power assisted steering altogether.
The power steering warning light is on on the dash with the exclamation mark next to it.
The power steering is completely off, nothing at all.
This happened very suddenly, I parked the car, PAS was fine, went inside for a few hours, came back out and it completely went. No warnings, no gradual build up and no issues with sticky steering in the past.
So far I've disconnected the battery, had it checked at Halfords (its perfectly fine) and left it on trickle charge for a few hours just in case.
I've also removed and replaced fuse no 22 (5amp). Although I'm certain the fuse was fine it's worth a punt.
I'm going to try and get this thread from problem to solution because there have been some great posts by really knowledgeable people on this subject on various forums but I haven't found a thread that's actually come to any sort of conclusion.
There's one very thorough thread about taking the steering column apart completely but that's simply beyond my abilities.
There's adverts on ebay like this one that claim to refurbish your EPS motor, but what if that's not the issue? I'll spend £300 just to be told the problem must be somewhere else.
https://www.ebay.co.uk/itm/BMW-Z4-Electric-Power-Steering-Column-Motor-Rebuild-/401352168863?_trksid=p2349624.m46890.l49286
Obviously I'd still have to pay someone to get the motor out.
My biggest concern is the overall price. I've seen all sorts of figures banded around all the way up to £3,000 which simply isn't an option and is ridiculous for a car that's only worth £6,000 at best.
If it's an entire steering column removal and refurb, is there any possibility of putting in a Z4M hydraulic unit back in instead?
Is it worth getting an entire second hand steering column from a decent BMW breakers and doing it that way?
Seems a bit daft to remove one clanger of a part by BMW only to replace it with an identical one that could fail again in no time.
Needless to say I'm hugely frustrated, expecially on a day like today with the sun shining.
Any advice welcome. I'll try and get this thread to some sort of a conclusion however much of a nightmare it is.
Paul.
Edit - one final thing. I have a vague memory of a sweet yet burnt smell as I got out of the car after it was parked up, a bit like candy floss. This could be a total coincidence though but could it be a burnt out motor?
Also the car has had bigger wheels, 19s (also heavier I think) put on in the last 150 miles.
Paul.
