There are actually two other connectors up there! So go careful.thecremeegg said:Help needed please!
I have everything disconencted but the one thing holding me back is the connector on the back of the EPS motor - I can't see how you undo it as access is poor.
I've removed the big one but the smaller one isn't a connector I've seen before - any help would be appreciated!
One of them is ty-wrapped along the motor body too.
I carefully pulled the motor back and lowered it down until I could see what I was doing, then snipped the ties and unplugged the connectors.
Be sure to hold the weight of the motor while you're doing it.
If it's a manual car you will also need to push down the clutch pedal to clear the motor.
I did it while laying upside down in the foot-well. I recommend some padding on the pedal as the easiest way is to push it down with the back of your head!
