Validwarlord
Thanks Guys for your input should interesting going forward.
Dave will PM you.
Dave will PM you.
Validwarlord said:Will check it out thank you very much![]()
You also need to code (expert mode):
CAS : FH_KOMFORTF_MIT_SUBST
CTM : KOMFORT_SCHLIESS_FBD89
Kevin said:I just tried this, having enabled the general options.
On my 2011, the second option seems to be called
CTM : KOM_SCHLIESS_FBD_E89
But this doesn't seem to have worked (mirrors not folding/unfolding for me on lock/unlock), so some more investigation is needed.
HOWEVER, somehow I seem to have enabled opening the roof by holding down the key fob. I didn't think this was
possible without Comfort Access, which my car doesn't seem to have!! [And I'm pretty sure it doesn't have a Smart Top]
All very mysterious, but I'm having fun![]()
matsmith749 said:In bimmercode expert mode, if you slide your finger down when in the first menu, you can search.
I'm pretty sure the CTM as noted in my message is exactly right..... maybe the reason it has not worked is that you have changed the wrong thing!
