These are the post bases we got:
https://ozcobp.com/product/6x6-post-base-ls/
As you'll see, they are from the US and feckin' expensive! Got them through Amazon and shipped from somewhere in America to here in 6 days. We had 3 of these, and 1 pack of the "s" hangers which has 2 in it.....weighed a tonne, its real heavy stuff.
The centre hole is recessed, and the actual bit that the post sits on is raised a few mm off the ground, so its got a bit of a standoff to help water drain away. A bolt might just fit but it would be tight, hence having to set the chemical bolt carefully...and as you say, thats a faff and doomed from the start. Technically I could just drill a wide hole in the bottom of the post for a recess, but would rather not.
I read somewhere to avoid drilling closer than 4 inches to the edge of the slab.
So those screws have potential. The centre hole is 16mm so i'd need a big washer or see if they do wider screws...looks like 10mm are biggest in that range. The base also has 4 separate holes I could use instead which are 8mm, so would fit perfect, but would I be ok drilling 4 holes so close?
Forgot to say earlier....will take pictures when its done! If I'm happy with it, plenty of pictures! If its sh1t, then probably just one blurry picture
Now I have the actual post bases, if the rain stops, I'm planning to go out this weekend and work out where to put them....possibly even fit them this or next weekend.
