enuff_zed said:Well I'm heading to Perranporth for a week on Sunday night. That'll be a bit closer.MikeyH said:As I have already said on here, I wish I lived closer to you.
Not sure I'll be allowed to play cars though. :roll:
enuff_zed said:This started as a bit of a joke, but it appears to be gathering pace!
So tell all your friends, there's a bloke in Attleborough who would dearly love to retire, or at the very least cut back his working days, and if it can be done by helping others to keep their Z4 on the road then I'm your man!
Main experience is E85 M54, but the only way I can expand that is by working on others.
I'll be 100% honest and only take on stuff I understand.
If you need any help, advice, parts, servicing, someone to look over a car with you, or just a chat with a fellow nut, then get in touch.
PS. My body is telling me no more than two roof motor moves in a weekend! So get in early. :wink:
More than happy to help you if I can. I am still in the learning phase on the N52 as I have concentrated more on M54 up to now.Dr_Tripwire said:enuff_zed said:This started as a bit of a joke, but it appears to be gathering pace!
@enuff_zed are you still open to helping out with issues? I'm in Ipswich and have had my local indy try to resolve the P0171 & P0174 issue on my coupe (3.0si N52) twice - the first time they replaced the VVT gasket, the second time they replaced the VVT rocker gasket but no luck...I've had the car off the road for a few weeks (only as I use a smoky old Saab as a daily) but want to make use of it again. What do you reckon? Would you be up for a visit for some help?
enuff_zed said:More than happy to help you if I can. I am still in the learning phase on the N52 as I have concentrated more on M54 up to now.
Therefore I am asking a few other members for advice before you waste a journey.
Well Colb immediately suggested a smoke test as the codes do suggest lean running and as it is both banks it would suggest something on the intake side rather than a sensor issue on the exhaust side.Dr_Tripwire said:enuff_zed said:More than happy to help you if I can. I am still in the learning phase on the N52 as I have concentrated more on M54 up to now.
Fantastic thanks! I may see if I can get a local garage to do a smoke test if I can get an appointment with them this week to at least rule out a leak but will keeo an eye out on here for your thoughts on a potential visit - much appreciated.
enuff_zed said:Is your engine silver top or black top?
Yes highly unlikely for both banks to fail, so look for a common link.Dr_Tripwire said:enuff_zed said:Is your engine silver top or black top?
Ah ok, so I've gotten in touch with a garage to get it booked in for a smoke test so that's a step in the right direction. I also read that having both codes appear would mean it's less likely to be oxygen sensor related... It's a black top
enuff_zed said:Yes highly unlikely for both banks to fail, so look for a common link.
I believe black top engines have the CCV built into the rocker cover.
But you can buy a brand new rocker cover with all the seals etc for under £100. Not too difficult to change either.Dr_Tripwire said:enuff_zed said:Yes highly unlikely for both banks to fail, so look for a common link.
Thanks... I guess it'll be a case of seeing what comes from the smoke test, then the MAF (the connector and plug are clean and corrosion free), then if all else fails the CCV - having done a bit of a read up I'm hoping it's either a vacuum leak or worse case, the MAF as I think you're right about the CCV being under the rocker... Hopefully I'll know more in the coming days!
Thanks again!
enuff_zed said:But you can buy a brand new rocker cover with all the seals etc for under £100. Not too difficult to change either.
How much is a MAF? Decent make?
To check the MAF you can disconnect it, clear the codes and see if they come back. The DME will run the engine on a default map instead.
enuff_zed said:So your symptoms seem to point to an air leak.
Smoke test first I think.
I wonder what quality seal they used?Dr_Tripwire said:So I had a smoke test done... The VVT gasket work the garage have done doesn't appear to have been done and tested...I took a video but not sure I can upload it here.https://photos.app.goo.gl/tUYT4krr3eu2QZTV6
Not sure how to embed a photo but have added a link to one...This is the best I could capture as a still image from the video but there's quite a lot of "smoke" coming out with you're stood at the car.
https://photos.app.goo.gl/x4duCjYpdMw9xpd69
The chap was very good, cleaned the MAF sensor while he was at it but wasn't wanting to attempt repairing the issue other than to tighten the bolts a bit more. This didn't make any difference though.
I'm not sure where I stand with the garage, their investigation and 2 attempts to repair have cost over £200 and I'm wondering if they would agree to a no charge repair as goodwill (as it was 6 months ago that they did the work but I've not driven the car since).
enuff_zed said:I wonder what quality seal they used?
It is actually a very simple job to fit a new seal.
Speak to the garage first and show them your video, but if they won't step up then we can qwuite easily buy a new seal and fit it.
I could come to you for that if you dson't want to drive the car.
Of course, cannot guarantee that will fix the fault, but until you cure that leak you can't move forward.
Sounds like you've found a better mechanic! Keep him onside.Dr_Tripwire said:enuff_zed said:I wonder what quality seal they used?
Sorry for the delayed reply - I've done a bit more reading up and it seems like a common problem as the OEM gasket isn't great - https://www.e90post.com/forums/showthread.php?t=1798605.
The mechanic who did the smoke test has suggested some alternatives - one being gasket material and K2 gasket maker/sealant. He's offered to help with the fix and will do another smoke test to make sure it's all ok - but I really appreciate your offer - thanks very much.
I've decided to write off what hte garage has done as I'll never get to see them do the work again even if they did agree to do it and my concern there is that they will hand it back to me and I'll face the same issue.
If this doesn't resolve the issue with the errors/EML and hunting revs at start up, I'll go get a replacement MAF sensor and see if that does it. I also read up about the CCV and one suggestion as an eay check is to remove the oil cap with the car idling and see if there's strong resistance/suction - apparently that's also a sign off an issue with the breather...that'll be the last thing on my list to repair if the VVT and MAF work doesn't!
Once this is done, I'll be working on the rest of the small list of things - the drivers window regulator decided to go bad so I have another on order and I'm planning to look into the reason why when engaging D or R (Auto box) I get a clunk....I think it's something to do with the auto transmission position switch but I'm yet to further investigate![]()
enuff_zed said:Sounds like you've found a better mechanic! Keep him onside.
HQ of 'Norfolk Zed Re
Ah, that'll probably be my better half. She is always handing them out for me.Zedsdeadbaby said:Hi, I'm new to the forum and been to track down Norfolk Zed Rescue and found reference to it here on a Google search. Not sure if enuff zed is still active but on a really wet day last year a card was left under my wiper, it was pretty soggy by the time I found it and the number was unreadable. Would be good to make contact. Thanks
