Steven4018 said:And did say the headlight washers are part of an MOT if they're installed on the car?
Correct, if headlamp washers are installed they must work otherwise it's a MOT fail
Steven4018 said:Also said something about the brake fluid is over-due a change and should be done every two years? And the engine oil should be done annually? Mentioning to check on 'honest John'
Correct that the brake fluid should be every two years but bmw used to say if he car was being taken off the road then to disconnect the battery as this stopped the clock and could prolong he life of the fluid but I'd always have it done at two years. As for oil this is again every two years or when the dash tells you. It's most defiantly not every year!
Funny I was speaking to someone yesterday who took their car to another garage and the boy there told them they only needed a 'mini' service and will need the full works next year which is utter BS. Pointed this out and he said I'm only going on what he told me and I advised what he'd been told was kak and pointed out what should have been covered in his service.
